Can not see my BS Essence at Bang & Olufsen app
Dear forum
Do you know why I cannot see my BS Essence at my Bang and Olufsen app? I can only see my Beolink Converter ML/NL. So i cannot turn the volume up and down at the app. I will upload i picture also.
I would try to restart your router
I have problems sometimes when the Essence is on my 5gz network and my phone is on the 2.4ghz network (or vice-versa). If you have both networks, try connecting your phone to whichever it is not currently connected.
I don’t understand why this would matter since I would expect the router to route between networks, but it seems to.
Stan
Power down all NL sources - especially any TV connected to the MLNL Converter.
Power down all Beoplay WiFi sources
Reboot TV (if applicable), then Converter, then everything else.
Are you using any Powerline products?
I have reset my essence without any luck and also started up my router and converter more times.
I don't make any sense that my converter plays tunein as it don't have tunein
Everything has been restarted more times
please see screen shot below
I don't know how many of you that understands danish - but it say that the beolink converter is in a intergrated setup with beosound essence. Do any of you know what that means and if I can get rid of that?
