I'm looking to set-up a wireless home theater in Dobly Atmos configuration. However it seems the transmitter supports at most 7.1 so I guess I should look for another vendor. Can someone confirm me this is the case?
Can I use beolab transmitter 1 in a dobly atmos set-up?
This is true. However you could always add more Transmitter 1's to the setup.
The Beolab transmitter support 8 channel so you choice if it has to 7.1 or 8.0 or 5.3 or what you want
How can I do that? I couldn't find anything in the manual to suggest that multiple transmitters can be paired
At os requires 7.1.4 so I think I'm 4 channels short
Seems are right! If you have enough Beolab T1s in theory you can each up to 72 sound channels(each country seems to have about 9 channels available on the 5Ghz band).
