Hello everybody
I intend to try those cable but I wonder if I will be able to use my internet Hub with no damage at all.
Thanks to share your experience and knowledge
Olivier
Hello everybody
Olivier
ML over CAT7 must be completely separated from TCP/IP Internet, Ethernet, ...
Start at the beginning and read the B&O installation book carefully ... 😁
THanks Vienna for your answer.
Cat 6 should be enough, don't you think ?
Best regards
oLivier
Cat 6 or 7 is of no importace as long you are using the cable for analog MasterLink or PowerLink.
But the layout (construction) of the cable is very important!
You need a screened / shielded cable + each twisted pair being seperately shielded/foiled.
B&O recommends/sells Cat 7 - S/FTP cable (Screened / Foiled Twisted Pair) from "TYCO"
Any Cat 6 or Cat 7 cable described as:
S/FTP = Screened / Foiled Twisted Pair
S/STP = Screened / Shielded Twisted Pair
F/FTP = Foiled / Foiled Twisted Pair
SF/FTP = Screened & Foiled / Foiled Twisted Pair
should do the analog ML/PL job properly.
PS: keep in mind - in the future - in a B&O "all digital" NetworkLink installation you might
need the higher bandwidth offered by a Cat 7 cable ...
