Can Earset1 mobile be used with Blackberry?
The subject says it all really.
The Bang & Olufsen dealer site list a range of adaptors that can be fitted to the end of the cable from Earset1 mobile to enable use with a selection of mobile phones. The Blackberry (model 9700) isn't listed but I'm reliably informed that a third party adaptor may do the trick.
Does anybody have any knowledge of this or can point me in the direction of a website that could help?
Opman
looks like everybody is as stumped as me on this one. Out of desperation I tried a Maplins 2.5mm stereo jack to 3.5mm stereo jack convertor. It worked 50% in so much as the caller to the Blackberry can hear but the Blackberry doesn't hear a peep.
Back to the drawing board 🙁
Opman
the Blackberry Bold 9700 uses the same standard 3,5mm stereo jack like
- iPhone
- Palm PRE...
- Blackberry Bold 9000 (etc.)
 - SonyEricsson Xperia X10
if not every manufacturer uses it's own pinout, it should be compatible.
How about trying it out at your local B&O dealer? Should be the easiest solution :)
my dealer changed  my earset 1 serene for a Iphone by putting a new jack on it
