Can Beo LIt 15 be repaired
Hi guys my Beo Lit 15 stooped working, completely dead.
Do you know if it possible to open and fix this speaker?
Thanks for guidance
Zoran
Hi Zoran
Any fault with the product due to manufacturing issues should be covered under international warranty. Go to www.beoplay.com/support and log your issue there. If you open it up it will invalidate the warranty.
Regards
Stuart
Stuart was right with his advice.
I did it with my H8 headphones. You will enter required pickup information and Beoplay will organize a pickup of your faulty Beolit by a parcel delivery company (like DHL, UPS etc)..
Once fixed, they will ship it back to you.
Not very easily and in most cases you will break a piece of the housing. But it can be done. Obviously, out of warranty.
Thank you for your advice!
