Hello,
Has anyone here drilled a hole through the wall behind a floorstanding beovision? I am curious about a way to hide cables all together, so Im considering drilling a hole high enough so that the cables cant be seen below the TV. Not sure though if this can be done in a way that looks good from the sides as well is practical.
This is in regards to an Eclipse gen 2.
Cabling through wall for floor standing TVs
Hello,
Another way of hiding cables.
I had an aluminum plate cut at a DIY store and glued two brackets to it.
All cables run in the "sock" which passes behind the plate by a triangular cut at the bottom of the plate.
Then, the cables run through the wall and floor and arrive in a cabinet a the basement level where the other sources are placed.
Regards,
Yann.
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
I’m sure it can be done nicely.There are “cable hole linings” for desks that maybe can be used for this.Example: Login to view imageHello, Has anyone here drilled a hole through the wall behind a floorstanding beovision? I am curious about a way to hide cables all together, so Im considering drilling a hole high enough so that the cables cant be seen below the TV. Not sure though if this can be done in a way that looks good from the sides as well is practical. This is in regards to an Eclipse gen 2. Beolab 50, Beolab 20, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9i, BeoPlay H6, EarSet 3i, BeoVision Avant 55, BeoPlay V1-40, BeoCom 6000 and so much else :)
Yes, I did it for my Avant. On the other side of the concrete wall all equipment is hidden. Considered drilling the hole higher up behind the TV so cables wouldn’t be visible. But the day we move the TV the wall would not be so nice with a hole a meter up from floor, so I placed it at ground level instead. Login to view image
Yes we use a one or two gang box with brush front plate. Either route the cables in the wall and plaster over or run into a stud wall or trunk. All depends on the type of wall and stage of install.
