Does anyone know the model number for this cabinet from B&O Beoworld does not list it online. They show every cabinet but this one
There are a couple of ways to add a photo. One way is to use the "Options" tab (next to the "Compose" tab). On the Options screen there is a button to attach a file like a JPG.
Another way is to first upload pictures in your Files section under your profile. Then use the filmstrip looking icon (next to the hyperlink/unlink icons) to "Insert Media". Clicking that icon lets you browse to your Files folder in Beoworld profile.
The first way (using the Options tab) is the easiest but you are limited to adding just one picture I believe.
The second way allows you to insert several pictures in one post.
Hope that helps.
-sonavor
Your Model is the System Cabinet SC 70
Thank you for the reply and pictures. Beautiful furniture.
What are my chances of finding the metal stand that goes with it?
Good chance?
Slim?
No chance in hell?
Very slim to no chance. However, it is a simple metal frame that is welded together so I think a metal shop could reproduce it pretty easy. You can see slots on the underside of the cabinet. The slots fit onto the metal frame.
-sonavor
I did what you advised me to do and took my metal frame to a machine shop and they copied it perfectly.
It looks identical to the original, but much heavier. They used box metal but solid metal. I painted it to look like
the original and you cant tell the difference. It cost very little for the metal. It was the labor that cost.
I paid $170 for the copy, but it was worth it. Thank you for the advise.
Thomas
Nice. $170 sounds reasonable to me. Please post a picture of the result.
-sonavor
