BV8 - my first view and observations
Hi
I have just spent the last hour at my dealer who unpacked a BV8 and hooked it up - have now had a good look and listen to it and have the following observations:
- Looks are subjective and do create strong reactions (dealers admitting they are still getting used to it). The logo which is recessed and can only be seen on an angle is a lot more pleasing than the first 'huge brand' pictures I saw.  Sliver grill is the same material and quality as newer speaker covers and the rest the surfacing is rubberised.
- The picture, right next to a BV7, seems to suffer more from glare but picture quality in lower ambient lighting conditions appears to my untrained eye very similiar.
- Less subjective is the sound which is very impressive indeed (and will really challenge all of the bacic range TVs below BV7).  IMO the sound is good enough to use as a stereo in a smallish link room and I will use it as a visual way of controlling itunes via ML, beoport and BS3 for bedrooms
- Pricing - UK dealers have had to revise original pricing down by £350 on instruction from HO - smallest TV now £1650 with no toys - with ML and most stands about £2000.
So, still expensive no doubt, but with ML added and with the quality of the sound in particular makes a proposition for itself as a reasonable link TV - one which I will try out in one of my bedrooms.
Where did you see the TV?
Glad to see they've lowered the price, but shame there is not digital tuner option.
B&O in Knightsbridge, London
what is the sound like compared to the BL7-1?
thanks for input!
Not in the same league as the 7.1 but better than its size would suggest and better imo than the 6-26
There is a reasonable possibily it may upstage the BV6 - time will tell - it certainly has for me.
i'm really waiting for the BV8 in France !
Do you think the 32" version can be a replacement of my BV3-32" ?
I really like the design and the stand program.
And apparently, the sound could be superior to the BV3 !
