BV7 without center speaker
I am currently using my BV7 in surround setup with 4 BL800 and 1 BL2. I am not 100% happy as sometimes the wrong audio signals are very loud making it hard to watch movies. I read others feel the same.
I am thinking whether I should switch away from my 5.1 setup and instead go with 2.0 or 2.1.
I was wondering whether anyone has a setup with a BV7 without center speaker. Is it easy to remove the center speaker and how does the BV looks like once removed the center (I have a floor stand).
It would look fine, just the panel may look too high without th speakers.
perhaps just disconnect or disable the Center speaker and leave it there?
I think you should be able to setup your speakers in a way that satisfies you. Your settings are probably not perfect.
Always use a center speaker!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
