BV7 sound scales
😭Hej,
Can`t the BV7 mrk III read the new sound scales: Dolby digital plus, Dolby true digital, and DTS digital  sound?
I have connected a Toshiba HD-DVD E10 to my BV7 with HDMI and set it up in the TV menu with both sound and picture as HDMI.
When I Play a HD-DVD the back speakers in my sourround will not turn on. I can force it with beo 4 by choosing speaker 5, but the sound is very low og bad. the sound  transmitting from  the tosh. to my TV is dolby digital plus. In the menu activ sound system on my TV it says sound in: PCM and sound out: multichannel. When I play SD-DVD`s  from TV or TOSH. no problem the back speaker turns on as they should.I have asked the dealer about the problem but he could not solve it. He had asked Struer, but still have no answer after 4 weeks..
Do any of you have problems with sourround sound when playing Blue-ray or HD-DVD on you BV 7 mrk. III.?
yours
trucker
Does anyone know the answer (or have any suggestions) ?  If it's taken Struer 4 weeks and no reply, i guess it's a difficult one!!
Lee
Hi!,
Is`nt there anybody who have experiences in playing HD-disk or Blue Ray disc, through BV 7III?
Trucker
Hi` moxxey,
Sorry, it is a BV7 mrk. III 40. As you can see from earlier post I can`t get sound i the rear speakers. When palying DVD`s all speakers turn on. The sound source from the HD-palyer is Dolby digital+ and think  may be the BV7 cannot read that scale?
It must then be the HD-player that there is something wrong with if you have no problems.
Do you have a surround set up?
Thank you for your quick replay.
