ðŸ˜Hej,
Can`t the BV7 mrk III read the new sound scales: Dolby digital plus, Dolby true digital, and DTS digital sound?
I have connected a Toshiba HD-DVD E10 to my BV7 with HDMI and set it up in the TV menu with both sound and picture as HDMI.
When I Play a HD-DVD the back speakers in my sourround will not turn on. I can force it with beo 4 by choosing speaker 5, but the sound is very low og bad. the sound transmitting from the tosh. to my TV is dolby digital plus. In the menu activ sound system on my TV it says sound in: PCM and sound out: multichannel. When I play SD-DVD`s from TV or TOSH. no problem the back speaker turns on as they should.I have asked the dealer about the problem but he could not solve it. He had asked Struer, but still have no answer after 4 weeks..
Do any of you have problems with sourround sound when playing Blue-ray or HD-DVD on you BV 7 mrk. III.?
yours
trucker
