Hi, i try to connect Android Box to BV7-32. I connect video through DVI ( HDMI to DVI cabel) but I am unable to get sound from device? Box have only analog audio out through 3.5mm jack. I have 3.5mm to RCA jack cable. As Box input I select AV1 and VMEM as source. But unable to indicate audio input. There is only A1-A4 digital input as choice and seem no analog inputs. Any help 🥺?
BV7 SOUND PROBLEM
DVI is visual only, you need to utilise the phono (RCA) jacks and assign them to the channel, then plug them into the Android box audio in. Although reading the post it looks like you do not have audio in? Never used an Android box so unable to help on that. On a SKY box for example it works very well.
You should be able to connect audio via scart (av1)while using DVI for video, so get an adapter scart>cinch and a cable cinch>minijack.
