Bv7 anti reflective screen
Hi all
Qucik question.
The bv7 anti reflective screen is it a separate screen than the main screen that goes in front or is it all once peice.
Im thinking back to when I had my bv3 screen upgraded.
If it is separate how mic are they.
Thanks all
The AR screen is simply a piece of glass with a number of fittings bonded to it.  It's replaced by taking the rear casing off the BV7 and unscrewing from behind.
When i say 'simply a piece of glass' it's clearly more than that - but i can assure you it's totally seperate to the LCD panel itself.
Lee
Hi there
That is the best news this month, I will create a tab for my niece so that when she is 16 she can pay me back for the chunk out of my ar coating.
Any idea how much they cost for a replacement?
They seem to have come down in price - from around £600 to around £400.
I'm going to order a few just in case it's a mistake on their part! 😂
Lee
