Hi everybody,
I want to setup, if possible, my Beovision 7-55 (type 7732) to broadcast the sound in 7.1 whenever possible.
My configuration:
- subwoofer: Beolab 2, cable
- front center: Beolab 7.4, cable
- front channels: 2 x Beolab 17, wisa
- surround channels: 2 x Beolab 18, wisa
- rear channels: 2 x Beolab 6000, wisa (via 2 x Beolab Receiver)
Of course, a Beolab Transmiter 1
Speaker roles, volume and distances are set.
Audio mode set to: speaker 5
Regarding Kodi:
Model: 2B / Kodi 18.3 (LibreElec)
Audio settings:
- Audio output device:  PI: HDMI
- Number of channels: 7.1
- Output configuration: Optimized
- Keep the original volume in remixing to stereo: NO
- Stereo to multichannel mixing: YES
- Passthrough mode: activated (PI: HDMI)
- Dolby Digital (AC-3) compatible hardware: YES
- Dolby Digital Plus (EAC-3) compatible hardware: NO
- DTS compatible hardware: YES
Problem:
All speakers are powered on and connected but the sound is broadcast by center speaker and subwoofer only!
Of course, I checked with 5.1 (but not yet with 7.1) movies.
For example, with a 5.1 movie (data from BV7 menus):
- Input format: Dolby Digital 5.1
- Output format: Dolby Digital +PLIIx MOVIE / Speaker 5
Remark:
Audio setting is set to Speaker 4 and the music is broadcast by 7 speakers (only the BL7.4 is turned off).
Thanks for your help.
Regards,
Christophe
