BV7-40 Motorized Stand control with no BV7
following the death of my BV7-40, I'm looking to replace it with BS3 + a non B&O TV. My idea is to adjust the wall mount to my existing motorized table stand, so optically there will be no major difference.
Checking on the BS3 connections, I was surprised there is no support for the motorized stand input, hence I cannot control the tilt / position of it. Is there a way to do, or the BV7 is the only device capable?
I think it should work with the data output.
Thanks for your reply.
Can you elaborate what you mean by "data output"? Is is a 8 PIN port on BS3, or something need to be adapted from?
I think it is the RS32-port. In the manual it mentions control of stand.
I'll talk with local B&O support shop to understand more on how to connect those.
Thanks!
