moxxey:
Afternoon,
Posted this in another thread, but what happened with the planned SD-based pixelisation 'fix' planned for sw 4.01? My BV7-40 MKIII was updated to sw 4.01 at the weekend, but SD content is the same as before and there's no sharpness setting in the customer service menu.
Beolab, what happened?
Hi moxxey! The sharpness setting is only a link from the service menu to the costumer service menu. It means that this setting is meant for Beo dealers not the costumer. The mail i published here at Beoworld was a Service inside mail for the dealers only.
Go in to the costumer service menu ( Menu + then set the marker at OPTIONS + hit the Red button twice then Go ! )
Now you Can see:
Customer Service Menu
SW VER
HW VER
ADJUSTMENTS ( Under adjustments you can turn on "Promotion Mode" an then see how the Vision Clear work´s live)
PICTURE ADJUSTMENTS (Sharpness settings)
SCREEN INFORMATION
SIGNAL INFO
And i have heard from a surce that in the 4.03 update the 24p and 30p will be able..
We can only hope it´s true! ;)
Regards
Hello . I have a BV7-40 on order that is to be delivered next Friday , should I insist that it has this 4.03 update and if not wait till a set is available with it ?
Richard
