It first started recently, 30secs after switching off the TV the red LED starts blinking. I do have a PIN code attach to the TV, but the power was never disconnected.
Does anyone know what this might be?
Thanks,
Tim
Thanks,
Tim
Maybe a Masterlink problem. Disconnect the mains for about one minute and reconnect. Everything should be fine now.
Stefan
Hi and Thanks for the reply Stefan.
I did, and it did go away, ok, it wasnt 1 minute... but the thing is that a couple days later it happened again...
Ill try it for a minute today... strange...
Hi Tim
I think it can be a software issue. Look what the new software fixes:
Build 433 (H8 SW 5.02). Support for DVB-HD. Teletext in P-P gives TV+TV. Intermittent loss of the PUC Table.
New features:
Symptom:
Cause
Solution:
To all above problems, please update to build 433.
Compatibility:
The
build is "internally compatible". This means that you must use the
entire build when updating the software, do not mix parts of the
software with other builds.
Guys, I really thank you all for it!
Ah, on the phone again to get this mess sorted!
Hi KingOfSnake,
Thanks for your response! Well, I do have a cabinet full of: an STB box, PSTN base, router and something else, but not light sources to be honest... :S
Im in the process of arranging a visit by b+o to upgrade the software, under warrenty, mmmaaaaybe it will fix it.
Thanks agian
Hope everyone had a great Xmas!
Sorry, for not posting the solution, the answer is to upgrade to SW 5.02, all, working great.
