BV7-40 + bl7-2: will it make sence to add bl4 as rear speakers?
Will it make sence to add the bl4 as rear speakers?
will I be able to use the sorround of the bv7-40 mkIV?
adding front speaker is not an option unfortunately..
No fronts - no rears... Reals only make sense with fronts... Check the internet for 5.1 Sound/Dolby digital etc. to learn more about it.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Is the beolab 7-2 not acting as both front and center if I add BL4?
As far as I know you can|t add configure them in setup. If you have some speakers to connect when you set up the TV, then you can remove them. In speaker 5-mode you will have center and rear. (You will lose right and left front.) Speaker 1 works as before...
