Will it make sence to add the bl4 as rear speakers?
will I be able to use the sorround of the bv7-40 mkIV?
adding front speaker is not an option unfortunately..
Is the beolab 7-2 not acting as both front and center if I add BL4?
As far as I know you can|t add configure them in setup. If you have some speakers to connect when you set up the TV, then you can remove them. In speaker 5-mode you will have center and rear. (You will lose right and left front.) Speaker 1 works as before...
