Hi all,
I have a BV 7-40 Mk III and would like to connect an AppleTV to it through HDMI. I have heard that the latest 2.3 software update from Apple allows you to "teach" your AppleTV the commands from another remote than the one supplied. This is obviously the way to go, as I would hate to have different remote controls floating around in my living room, depending on the device I want to use (one of B&O's key competitive advantages!)
Does anybody have any experience with this? Does it mean that you can hide the AppleTV neatly away, the commands from your Beo4/Beo5 going through the TV down to the AppleTV? Or does the AppleTV need to be visible, so as to receive the remote control commands?
NB: I am assuming that it's straightforward to connect an AppleTV to a BV7, but if it's not the case, your thoughts will be welcome!
Klaus
