I have moved my BV7-40 and now need to reprogram the end stops on the motorized stand. What is the procedure to do this.
Ron
Ron
See: https://www.bnoservice.nl/manuals/beovision7MK.pdf
, page 28. This might also be in your "Getting Started" manual because it was part of your initial setup. After the initial setup was done once, the menu item "Stand Adjustment", which is what you want -- gets hidden *inside* the "Stand Positions" menu (which itself, until setup was finished, remained invisible)?
Done!!
Many thanks, I found the "menu within the menu" option.
Ron
