BV6-26 issues
I just aqquired a BV6-26 that someone had thrown out. Aside from some small cosmetic details it is missing the speaker grill, the backcover for the connection panel and has no stan or feet. It is working fine thoughBecause of the missing speaker grill the speakers looks like this: Login to view imageIs this something I should try to fix? And if do how? I dont hear anything wrong with the sound when using it.Regarding stand options can anyone tell me about the feets that was availeble for this tv. Is it simply a little cylinder that is screwed up the button of the TV?A search on Ebay doesnt bring up feets or speaker grill but maybe im using the wrong search terms. Any suggestions?Thanks in advance
Exeter,
Devon,
UK
We have two motorised stands for these in our stores. One faulty
Scroll down this old thread to see how I repaired identical speaker damage on a BV6-22.
(Epoxy, matchsticks, pull gently, twist off. )
/forum/imported-unmapped/dreaded-child-finger-poke-damage---s75-phase-link-midrange
Graham
Thanks for all the inputs. Another little question is regarding the remote control.I have a BEO4 without the PC command in the list function ( and it cannot be added).Is there another way to activate the DVI port?
Why can’t you add PC?
It’s not an availeble item when I choose add to the list function. I guees its because its an old version of the BEO4 no DVD button, but an AV button instead
