BV14 stands
Stupid question but I can't find a definitive answer online.
It looks like BV11 and BV14 stands and brackets are interchangeable.  Can anyone confirm if this is the case because if it is I can see me sticking 14s on my existing wall brackets and buying floorstands to put the 11s into a family members house.
If I need to change all the wall brackets I dont know if I can be bothered.
It´s the same for both!
