BV14 and Core - issue when playing music
Hi BeoWorld!
I am using an integrated Core with my BV14 to play music to the surround system (BL17-19). Sometimes (appr. every third song) there is a small leap at the beginning of a new song. This drives me really crazy!?
Interesting is, that when I am using a M5 as the master and follow with the BV14 via multiroom everything is fine??
Any ideas whats wrong with the Core?
Is there a quality difference between streaming over M5 -> BV14 or Core -> BV14?
WR
To come back to my post from last week I would like to give an update.
Still there is a small drop when playing over the Core to the BV14 a new song from Derer or a Music Player. I addition to that my fallback strategy over AirPlay direct from a Music-App is not working anymore, after the update of the Core with AirPlay 2. There seems to exist some country restrictions!?
In my integrated BV11/Core configuration I had to disintegrate the Core after the Airplay 2 update, before I was able to configure Airplay for multi room again. Having done that I could integrate the Core again, and now I can use Airplay 2 on my BV11 speakers. It could be the same issue that you are facing with Airplay on your BV14/Core setup.
Best regards Dyssegaard
Perfect, AirPlay2 is running! Thanks a lot for your support!!
