BV14 and BeoRemote One BT lists
Millemissen wrote:
You can (re)name the sources as you please, when setting these up.
And you can decide if or not and where they should appear in the lists on the remote.
See page 24 - 'BeoRemote lists' in the userguide.
Thanks @millemissen for your help - I found this, but what I'm wanting to do is manage what is available when I press 'list' on the various sources I have. There's lots of default stuff in there I don't want displayed for example.
I'm guessing they will add this in an update if it's not there now as it means you can't edit what's shown for 'light' and 'control' when in Bluetooth mode. This is a whole other subject though about the BV14 and the BLGW which I'm going to be posting about in home automation!
Hi Chris,
do you see the option "Text" (Videotext) in your TV-"List"?
Chris....you have to do it on the tv settings....chose a source from the source list, select menu lists, and go from there.....it is different from the regular BR One...
what you can't do yet (i believe) is (a) edit the Music and TV list that appears on the home screen of the BV14......and (b) when you link a product to the BV14, all of those sources appear on the remote and home screen Music / TV icons......
guessing those latter two cases need to be added as options....
Thanks @sandyb I'll try tonight. Have had the parents down this weekend. I'm sure I didn't see this in the menus before but will report back.
You're correct on the other issues too. Annoying that I can't hide/deactivate the sources coming from my Essence over the network on the TV. It's even more frustrating that I can't set stand positions for sources and also set settings on the shared sources as you can on the local ones. Grrrr!
Still love it though :-)
Hi @sandyb have a look at the attached picture - there is the "BeoRemote Lists" menu but this just defines where the source is shown on the remote menus. I can't see anywhere to change what's show in 'List' for each source on the remote 🙁
yes, thus far, this is the way it works.....you go through each source (TV as you have shown above), and assign it to either / both / no list.....teh only way to see the results amalgamated list is on your actual remote......
so yes, there is nowhere on the settings menus to see what each lists comprises....only on the actual remote as mentioned above.....peroanlly i haven't found that a problem......or am i missing something.......
the real pain at the moment is that once you link a product, all of its connected sources show up, and there is no way to manage that list as yet....
Hi, I'm talking about what you see on the remote screen when you press 'list' on the remote itself.
ah i see..apologies.....not quite sure what you are trying to do....
when you press List on the remote, you will see a whole load of choices....so for me, right now i have :
BV14-55, SKY HD, OPTIONS, TEXT, STAND, SHOW PICTURE, FORMAT, SOUND etc etc......i can't edit that list of choices....
when it comes to the source specific functions, for example i can shift right on the SKY HD, and i get a bunch of SKY HD functions....i don't think you can edit that list of SKY specific functions either...but they seem the same as on a BV11 (for example) when you press menu, and about 7-8 source specific functions came up on the TV screen....dont think they ever showed on the BV 11 remote (for Sky "Record" or "Box Office" etc)....those same functions now seem to get sent to the bluetooth remote.....find them quite useful actually......but seems better than with the BV11 i.e. old system...
anyway, long winded way of saying, no i haven't found anyway to edit either the broader set of choices under List, nor the source specific functions......
Aye aye that's the menu I want to be able to edit. It's not the end of the world, but it is possible in IR mode and is just handy to hide things you never use.
ah i see.....with you.......having fun with the 14?
mine seems pretty stable now.....still have remote communication issues.....have to reselect the source and the remote then works.....but mostly all seems relatively fine now.......even enjoying the ability to stream from my phone to the TV (podcasts mainly), but useful i find....
