BV14 and BeoRemote One BT lists
Hi there, i have my BV14 installed. Woohooo. Multi room seems to be behaving etc. However I cannot for the life of me find out how to edit what appears in 'List' on the BeoRemote One BT for each source. Anyone got any idea?
Whilst we're on it - I don't seem to be able to set a stand position for each source as I could do on my BV11 - is this just not there yet?
You need to do it from the remote advanced options 👍🏻💯
You need to add the sources to LIST from the remote's advanced options 👍🏻💯
You need to add the sources to LIST from the remotes advanced option.
They maybe under the MUSIC button?
You can add and remove sources under MUSIC and LIST from the remote's advanced options under LIST.
lol
Regards
Kiran
Born in NL; I ride ML
Thanks for the response @Kiran but that only seems to work for when the remote is in IR mode. What is available in LIST seems to be sent to the remote from the BV14 when in Bluetooth mode. 😕
Regards
Kiran
Thank you @kiran but I think that's only for IR mode. The contents of LIST seem to be sent from the TV over bluetooth. I can't see any options to edit this on the TV though.
Wow I don't have experience with the Bluetooth side of BeoRemote One. Mine is IR. Is bluetooth built into the new remotes?
Hopefully someone will be able to help you 👍🏻
You can (re)name the sources as you please, when setting these up.
And you can decide if or not and where they should appear in the lists on the remote.
See page 24 - 'BeoRemote lists' in the userguide.
