If your BV11 has nothing wrong with it, i would keep it until it dies
Then, after that, i would pick the Eclipse over the Avant and BV12
I meant old tech, full led 755 mk2 vs plasma, not the same league for the picture quality
the difference is that the tech inside the 65 was older whereas the one inside the mk2 was new.
the difference is that the tech inside the 65 was older whereas the one inside the mk2 was new. 2010 it was mk1 not mk2
That's the biggest issue with B&O products: Do they ever die? My 1997 MX4000 didn't, finally had to replace it because of new cable TV standards (still watched TV back then), replaced with a used BC 6-26 (because my wife didn't want it bigger than the MX), which is still running and our series-watching unit. 😐
Basically Audio and PUC Control. Use a 4K settop box as TV source - but use it at 1080p only (no 4K/UHD TV channels subscribed). I use the TV‘s native 4K apps to stream 4K content (netflix, amazon prime, at+, disney+).If I ever use 4K TV I will get get a HDMI splitter (or similiar, no idea yet) to run the settop box directly to the screen.I use lintronic box to control the the via Beo 4 in TV mode.RalfRalf, I guess I'm really outdated: Full Array LED? I thought there was only OLED left nowadays. Checked your signature, so you have no B&O or 1080 HD screen anymore. What's the BS4's job then? Audio and PUC control only? What about 4K settop box or ATV video signals coming to the screens through the BS4?
Now to my question: I'm currently using a BV11-46 in a 5.1 (BL2 and 4xBL3) surround setup in my TV-room and now have the chance to get a near mint BV12-65 for less than 2k€.
I used to own a BV12-65. Loved it, raved about it. Also, of course, you can connect external B&O speakers.
But, frankly, my LG G1 panel leaves the old 65" standing. 4K on a 65" panel is recommended, particularly for sport. Love it. Wouldn't go back now. For me, G1 + Stage is ideal, although I'd love a 'NG' Stage which would allow for the connection of external speakers for an audio upgrade.
Moxxey, I've read your hymns on the 12-65, that's why I first sent you a PM, but you didn't answer, so I copied it into the forum :-)
Will the NG stage also work with my audio setup, I don't think so. As I'm watching nearly everything on my ATV and also have a STB, a PS5 and a Switch hooked to my TV, I guess I'd better try to get a BS4 without BV-12-65 somehow and wait for a more budget friendly used Eclipse. A BV remains a BV, something different! I like the idea of having a BS4 because that'd mean having less cables running to the TV, it has a pretty nice audio engine. I have neither 4k stuff in my video collection nor does our STB deliver that format yet. Last but not least I'd have to admit that I'm using Hue Sync, love that gadget. The BS4 would allow me to use it with all my image-feeding gear, now it's just synced with the ATV.
cc
