BV11-46: Wooden lamellas...
Is it possible to custom fit wooden lamellas to the 11-46? I seem to recall you can only do it with the 11-55 model unless anyone can advise otherwise? I have the later mark 4 version and just fancy a change that’s all. Thanks, Simon.
Original b&o ones don’t fit, seen some people make aftermarket ones, that could works if you like it. Looks similar but it’s not the same.
Or take a band saw to the original 55 one 😎
LOl cheers Miki! 😁
