BV10 thoughts after one year launch?
Hi Everyone!
I was wondering your thoughts about BV10 (40-46). Its been launched like year ago and it has been very popular topic in this site. Do you still think that BV10 is wow! and top TV on markets?
Im askin because im very close to buy one and wondering should I wait other BV launch in future...
JL
I own a BV10-40 and i'm very proud of it !
It has the Bang & Olufsen touch.
The best placement is on the wall for the WOW effect !
The picture is really stunning and the craftmanship out of this world.
Go for it !
I would consider one of these to replace my BV7 if the new universal video module allows the projector output the way the BS3 does
I have been waiting for the right TV for years now to replace my (what I beleive to be the best tube television made) BeoVision Avant DVD.
I had always wanted the BeoVision 7-32/40 since it was launched.  I never got round to buying one because the older versions lacked connections like HDMI etc. Also, I allways wanted and loved the BeoVision 5.  I loved the design and the fact that it was very different from anything else.  It was not HD and only a few models and then became HD but it was not up to speed with everything else.
When the BeoVision 10-40 came out, I absolutely loved it and what was a bonus is that it had all the boxes ticked (2 HDMI's, 200Hz, edge lit LED backlighting, Full 1080 etc etc.) At last, Bang & Olufsen have not only created a stunning TV, but it also has all the right spec and connections.
Also, because it looks similar to the BeoVision 5, it makes it every bit B&O!
Obviously I brought one.  Because I have a fire place in the way, I put it in the corner on a STB LUX pull & rotate bracket and it looks stunning.  Since living with it for a while, Its worth every bit of its price tag, and thanks to STB Brackets for a stunning bracket to go with it.
Well done Bang & Olufsen!
I hope that answers your question....
Matt.
Thanks!
Now im even closer to buy BV10... Its really stunning in my opinion.
JL
I was even more hesitant than you when I decided to buy mine. After have it installed for two weeks now I can tell you it was one of the best decisions I made in the whole home renovation project. It is really very well designed.
Just one recommendation if you are really a neat freak like myself about having all the cables hidden and looking perfect and you are not very handy then have it professionally installed. That is another decision that had me back and forward and now I cant tell you it was the second best decision I made about the beovision.
Just ask yourself, is there any other tv out there that you really like as much? Obviously my answer was NONE not even close.
I Have had my BV10-46 for 6 months now and it is now better than ever. When I first posted about the new purchace I thought it was fantastic but indicated that there was a small problem with cameras following fast moving small objects (ie cricket and golf balls). They occasionally became blurred and with multiple images of the ball.😭
My dealer inquired with technicians at the recent B&O dealer conference and they advised switching to "Game Mode". I did this via the menu when watching sky sports HD coverage of the Ryder cup and saw an instant improvement. Its now pretty much perfect.
For game mode; Menu-Options-Picture. Scroll down to "game mode" (at the bottom of the list on my TV). double click for on and a menu bar at the top of the screen briefly advises "game mode on". The mode only remains "active" for the channel you are on. It defaults to off again as soon as you change.
So, now that that is fixed I can say that I enjoy the picture immensely. The build quality is wonderful and it is a big improvement on my first generation BV5. And I never thought I would say that.😁
You can use the beo4 to activate Game mode to.🙂
I decided to swap my old Avant CTV 28" for a flat panel. Then I made my order this last saturday for a new BV10 46", with the motorized floor stand and the Beo5. I should received this one in close to 3 weeks.
I guess things will be different in a positive side, knowing the fact that the sound coming out of the Avant is a bit better than on the BV10 46".
Cheers,
Hi sja
Do you mean there is a shortcut with the Beo4 ?
