I've previously disabled the analogue TV tuner since as most other, I don't utilise any analogue input. But, I now realise that I'm not able to enter the BV10 Service Menu (MENU,0,0) or the TV Setup due to that when I press the TV on the remote it's then acts as DTV...
How do one re-enable the TV Setup menu function so one can access it again?
Also, when trying to go for the Customer Service Menu by pressing RED + GO while the cursor is placed on the CONNECTIONS field isn't possible either since I can't locate the connection field which I assume is in the TV Setup menu, or?
