When connecting a Blu Ray player to a BV 10 (or other similar TV I expect), is there any benefit in connecting the digital audio output in addition to HDMI or will the HDMI do the lot to the same standard?
S
S
Just connect the HDMI. Adding the digital audio out is of no use for "normal use"
There was a problem with PCM 2.0 decoding with the BV7, which is resolved by connecting HDMI+ analog audio, but this doesn't happen with BV10.
