Hello BO folks !
I have a BV Avant 75 with 3 sources : French STB, Shield TV and Zappiti 4K player.
Everything is connected to the HDMI ports of the TV and the PUC 1, 2 and 3 for having them controlled by the TV remote. It works flawlessly.
I want to use an Atlona Juno in order to have different 4K source with HDCP (shield for Netflix and Zappiti for NAS). So basically the OUT of the Atlona will be on the HDMI1 of the TV and all the devices will be plugged on it.
Here is my question.... There are only 3 PUC connector (1, 2 and 3) and I need a 4th one to control the Atlona. I saw that each PUC connector is labeled as A+B and I have plug with 2 sensors at the end, so I am assuming that I can assign PUC1A to a device and PUC1B to another one and thus, having a maximum of 6 devices controlled by IR.
How do I make the difference between IRA and IRB ?
Cheers,
Serge
