BV 8 system module
HI folks, can the system module for the BV 8 be fitted as an upgrade after original purchase? I have one I would like to ML up to the rest of my system.
   Cheers
   Jonnie
Hi Jonnie,
I got a system module unmounted with my purchase of my BV8-32 and after advice here I did install it, with no hazzel and was a true "plug and play". My original thread is here:
/forum/general-discussion-and-questions/installing-a-system-module-on-a-beovision-8---32
Hope everything goes as well for you
Cheers
Jesper
Sweden
I also added the system module to my BV8-32 without difficulty. I didn't really need or want the ML connection; I added the SM simply because I wanted a 4th PUC input. I have a DVD1, Apple TV, DVR/tuner, and computer connected to the BV8. I also have a pair of BL4000s and a BL2 connected in addition to the on-board speakers. I guess one might say that I have really maxed out the BV8. ;-)
Thanks for the replies guys. Do I take it that you did the install yourself or was it undertaken by B&O?
    Regards
     Jonnie
I did it all by myself (!?!?!? hope my superproud face dont show to much hehe). Even come with a disposable anti-static-ribbon to use when installing it. Snugg fit and no problems at all. Only downside was the carry and lay down of precious TV face down (used my bed).
Jesper
Sweden
Well done, just ordered one. Look forward to fitting it!
   Thanks for the replies.
Jonnie
