BV 8-40 PC connection
I have connected my Mac to the VGA on the BV8 and picture is fine. I have connected a Black and Red RCA to 3.5mm headphone jack to my Mac's headphone outlet for sound but cannot get any. When I go to Connection menu I choose AV3, PC, VGA and the only sound option I get is P/S dif! How do I choose the Red and black outputs (Is it component?)
I have previously used this setup on a Sony Baravia and it worked brilliantly.
Cannot get any sound through the BV 8 however. Am I missing something?
I think you need to connect the sound-output (L/R) to the AV3 scart.
Regards,
Bieele
So what are the red black and yellow RCA plugs for? I don't see any reference to them in the connections menu.
I'm not sure if this helps, but I had my BV7 and Beomedia1 connected as you described, minijack and L/R in the BV7 and it worked.
My BV8-40 and my Beomaster5 is connected using vga (only works on AV3) and audio using RCA L/R (BM5) to RCA L/R (BV8).
I will check tonight at home how it looks like in my connections menu.
Just to confirm my above post, now I have checked my connection. BV8-40 using L/R RCA from BM5 to L/R RCA BV8-40, VGA. In the connection menu it says AV3, source PC, IR none, HDMI none, YPbPr none, VGA yes, S/P-DIF none.
And it works, seems it automatically finds the audio / sound somehow.
Hope it works!
Thank you seems to be working now OK.
