BV-7 40 MkIII software
Does anyone have an overview of what is updated in the different software releases for BV7-40. Some kind of releasenotes or something from B&O?
In my case I am interested in what is new from my release 3.5 and up to the newest.
/Mikael
And: has anyone already spotted SW 4.2 ?!
Sw 4.2 will be released "soon" according to B&O. Maybe April....
Is there any word yet on a fix for the "white flash", or will I just give up asking, and pretend I don't see it anymore...
I've had three versions of software in my 7-40 and haven't noticed any difference between them . Arrived with 3.5 ( 3 weeks ago ) and had it upgraded to the latest 4.12 , it then started to shut down about once or twice a day , they decided to go back a version to 4.00 to see if 4.12 was the problem but still does it , looks like they are going to replace the set . They did tell me the difference between 4.00 and 4.12 and can't remember what but nothing significant . I've always had the white flash with Blu-ray ( pencil thin line bottom left ) but only on the menu , never during the film . I wasn't to happy going backwards with the software but perhaps the new one will have 4.20 .
Richard
Hi, if you have sw 4.0 you can get rid of the white flashes, just doing the following:
Go in to the picture-meny and when you are looking at bluray-movies the "size" potentiometer is activeted. Put the potentiometer one step below maximum. This will zoom the picture a little, but you will not see any white flashes anymore.
/Martin
The interference issue is SOLVED!!!!
My dealer has update my BV9 to 4.17a and NO 24p
....mr anders(son):
4.18 is the latest firmware, and the 4.2 24p upgrade i hope will be release during this month !
4.18?
4.17 is dated 080405!!
and this is for BS3 (BV9 and BV4)
Maybe 4.18 is for BV7 !
Beolab:
