BV 14-55
BBC iPlayer slow to launch, then watching 'Death in Paradise', when the well known flickering picture problem, followed by TV shutting down and restarting, via the Android screen. Has the update solved anything?
After installing the new software release I noticed only few improvements. The guide function is much more stable now. That is obvious.
The home screen is still one of the main issues. After having installed the software it worked for 2-3 times. But now it displayes only one line of apps and then freezes. It is not possible to navigate using the arrow-keys of the remote control. After a hard reset of the tv it's sometimes possible to use the home screen again. But even again for 1-2 times. Is there anybody else having the same problem?
Not having that issue....I was having crashes after the update, I was told to switch off the TV for 45 minutes, which would clear the caches...so far so good.....my picture quality has definitely improved compared to before....while the 45 minute cache clearing may have helped me, I suspect it I may get back to the same problem again....some of this just seems to be down to Android TV I suspect
Still crashing, lost connection to BT remote etc.
Unolugged the TV overnight. Fired it up and no sound from TV speaker. Shut it off an on again. Sound come back....ugh🙁
Unolugged the TV overnight. Fired it up and no sound from TV speaker. Shut it off an on again. Sound come back....ugh BeoVision 14-55 oak...BeoLab 8002 as FRONT....BeoLab 4000 as REAR....BL19 SUB copper 90's edt....BV5 2xHDMI....BV7-32 MK3....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...A2 Black Copper Special Edt
Take back your Bv11 :)
It will be hard..😕
After I made a power off over the night it got worse!!!
I'll wait after week 10. If it is not solved then I will return the TV!
