BV 14-55
Ok I have it for a week now and here is some reflections.
* Android system crash every day
* My Pace 830 box does not work with PUC
* When I turn on the TV from stand-by and, lets say press ATV, all puc controlled devices goes on!! (Except Pace box)
* When the TV has been off for a couple of hours I need to enter the pincode.
* The sound of the Pace box is out of sync
* If you change settings it does not apply.
* Automatic room adaptation is bad, so I have set it off
etc etc........................
Many of this issue is known by B&O
All I can say is that I  never had so many problem with a new TV as this;-/
Is it Andriods faults??
That sounds quite shocking. Ok, early adopter problems. Still, just too many issues. It's not Android'd fault. B&O needs to be blamed for releasing the product in such a state.
I hope, the issues can be fixed soon so you can enjoy the new TV. I was satisfied with my BV11-55 only after two years, there were a couple of issues. B&O fixed one and implemented another one with their updates.
That's disappointing, Mr. Anderson. I hope the issues are resolved quickly.
I have discovered the same issue with that excact Pace Box.
However, i have found a (temporary) solution. It uses the same IR commands as a Samsung SMT-S5140, so try to download that PUC and try i out. Seems to work well :-)
Wow that works🤩
Thanx Casperl!!!
(related to my BV14-40)
Indeed.. The Android part crashed regulary...  "service xyz stopped responding" and so on.
One evening turned off the TV because I had to put my daughter to bed and still do some work... some hours later.. turn on the tv and it's requesting pin code... Which I didn't have... Had to call my dealer the next day.
Takes at least 30sec to start up from standby!
Haven't had any issues with the PUC (Appel TV rev 4 and Telenet decoder)
To figure out: how to make a list of DVB-Radio stations so that I can press "Radio" "1" in order to have the first radio station that I have put in the favorites list
Also need to figure out how to add Spotify to the devices list so that I can assign the BL8000s+BL11 as speakers without the speakers of the BV14
B&O still need to iron out a lot of bugs in this one!
(duplicate)
Very very sad to ear all these issues for ordinary use.
BV11 was so good for that, BV14 shoud be at least the same.
I personaly dislike the Android stuff on the new tv but thought it would work well from scratch.
I was seriously considering a BV14-55. Maybe I should wait.
Depends how long you liked to wate.Thing is if/when they do add HDR everything will be 8k 🙁
