BV 14-55
I did the update and everything works fine. Also got the Atlona Pro3 1616 working with al the sources!
This is the new Leica M10
It improves on its 100 year history of superlative build quality, and state of the art materials by removing some functionality! No smart modes or scene settings, simple simple simple. This version actually had the video function removed because it's loyal fan base didn't want it. So the Germans removed it, and bumped up the price.
The waiting list is massive.
B&O, just make a simple to use and operate Tv, using the best materials and technology on the planet, all wrapped up in a classic elegant timeless design. Leave smart functionality to folk who know what they're doing, and charge a relative pittance for it.
It's worked for Rolex, Porsche, Leica etc for decades, it can still for you.
Aha! May I ask how? If I enable the matrix on HDMI1, I then can't see any HDMI1 source (never mind any matrix source) Am I missing a step (or three!?)
TIA!
TIA!
When I enabled the Matrix there was a Matrix 1-16 in the source list
Blast, not on mine :( Anything special about your config, or just wired matrix<>tv on hdmi 1?
what matrix are you using? i have the same problem as you.......added the matrix, but cant see any additional sources.......what is odd is that i can use the matrix's web page on safari to access the matrix connected sources...(i have a Pulse Eight)......so the matrix is passing the sources through to the BV14, but i cant use the BV14 menu's etc to control them...........
I have an Atlona AT-UHD-PRO3-66M
The matrix is online and working fine, I can manage it perfectly from my Avant, and can use the web GUI as you, to switch sources and watch them on the Horizon and 14, but no sources in the 14/Horizon menus....
Try to select the 8x8 UHD matrix then it will work.
Try to select the 8x8 uhd matrix
Thank you thank you! It works! Odd - is the 66 implementation buggy?
