BV 14-55
Aha! May I ask how? If I enable the matrix on HDMI1, I then can't see any HDMI1 source (never mind any matrix source) Am I missing a step (or three!?)
TIA!
When I enabled the Matrix there was a Matrix 1-16 in the source listAha! May I ask how? If I enable the matrix on HDMI1, I then can't see any HDMI1 source (never mind any matrix source) Am I missing a step (or three!?) TIA!
Blast, not on mine :( Anything special about your config, or just wired matrix<>tv on hdmi 1?
what matrix are you using? i have the same problem as you.......added the matrix, but cant see any additional sources.......what is odd is that i can use the matrix's web page on safari to access the matrix connected sources...(i have a Pulse Eight)......so the matrix is passing the sources through to the BV14, but i cant use the BV14 menu's etc to control them...........
I have an Atlona AT-UHD-PRO3-66M
The matrix is online and working fine, I can manage it perfectly from my Avant, and can use the web GUI as you, to switch sources and watch them on the Horizon and 14, but no sources in the 14/Horizon menus....
Thank you thank you! It works! Odd - is the 66 implementation buggy?
