Delighted with the Spotify facility now on BV 11 - nicely presented and works well.
A small mystery, though.
My Beosound 4 works through the BV11 and linked speakers Beolab 9s and Beolab 3500  via the Netlink Convertor for the ML-network.
If I've been using radio or CD with the Beosound 4 and then immediately access Spotify via the BV source menu in the usual way, Spotify music stutters and starts all the time. It only does it then, and my home network is fine otherwise - e.g. for iplayer etc.
There's no problem at all if I access Spotify without routing through the Convertor, but instead reach it directly from the BV 11.
So the 'problem' doesn't really matter. At the same time, if Spotify as a source isn't really available when Beosound 4 is 'active' for radio or CDs, I feel it should be blanked out from the source menu.
Anyone else had related issues?
Andrew
