BV 11-55 clouding?
I am looking into to swap my BV9 for BV11-55. Is there any "clouding" on BV11-55?
You don't like your BV9 anymore ? 🙁
Yes, there's some clouding on the BV11 as it's side-lit, not locally lit, like the BV7-55. If you don't want clouding, get the BV7-55 MK2.
The 7-55 has the superior screen hence the price difference. Not many around now...
You'll only notice it in the pitch dark , in normal viewing I doubt if it will be a problem.
Liverpool store have 3 x 7-55's, priced at under £10000. Includes screen, motor stand, bl7-6 and beo6.
the problem with the 7-55 is the sheer size and weight
amazing tv , but a leviathan
personally i pefer the 11 .much more acceptable imo
in fact fingers crossed i'm trading my avant in for one in the next few weeks
welcome to the 21st century flappo LOL
i've got a couple of old beo lab 6000's that will work according to the bno rep
quite excited , apple tv the lot
woohoo!!!
Most likely MKI sets based on this price?
They are 3D so therefore mk2 !
