BV 10 wall bracket.
Hello,
To fix a beovision 10 on the wall, I'd like to know if the wall bracket is the same for the 40" and the 46" models ?
I intended to fix my BV10-40 and upgrade it to the 46" screen in the near future, without changing the stand. Is that possible?
Thanks, Marc.
The wall mounts are different.
Thanks for your answer.
I'd better try to change my 40" before hanging it up.
Marc.
