bv 10 and bv 11 : same stb wall mount ?
Hello,
According to you, can we use a bv 10's stb wall bracket for a bv 11 ?
If I remember correctly, no! I had a BV10 and moved up to a BV11 and they had to remove the old bracket and install a new one.
I had this: link
Had to change to this:
Thanks Moxxey.
Yes you can!
I replaced my BV 10-46 with BV 11-55 at my summer house. I ordered a new wall bracket but used the old one.
The bracket was "close wall bracket".
