I own a BV7-mkIII connected to a BS9000 plus 2BL6000+2BL3+1BL2 and it works perfectly. I’m considering to buy a BSound 5+ Beomaster5. Can I have both systems in the same network? My dealer has told me that only one Music System can be the master but he was not 100% sure.
Another doubt is if BM5 can be used as a “hdr2” in the sense of being used to record programs from TV.
Has anyone replaced the DVB-T / S for the new DVB-T.HD for high definition? I think to replace the decoder to the new one, means you have to take out the DVB-S.
Is there any quality difference between connecting a device with DVI or HDMI? BM5 doesn’t have any HDMI conection.
Regards,
Xavier
