WMA, does anybody seriously use WMA?
Most of my digital music is in WMA format.😂
Craig🙂
Craig🙂
Craig🙂
Bonne annee à vous aussi!
This is the link:
Brilliant - thanks for that!
Another question, with sw 2.01a is 2gb still the max size of sd card?
tony
Bonne annee, Tony!
For SW2.01 2Gb is the limit.
Depending on the Ser.# of your BSd4 :
An update requires either just a new SW via ServiceTool of your dealer/service
or an additional change of EEPROM before updating the SW.
vienna
ser no -- 20366671
can you give an idea of cost for sw update in €
salut
tony
Hi Tony
Please check your current AP-SW-Version:
Menu -> Setup… -> Options… press [0 + 0 + GO] -> SW versions…
IF: AP-SW is 2.01 or higher
THEN: only an update to AP 2.15 / Codec 04 version 1.31 will be necessary (via service tool)
costs: approx 1/2 hour = +/- 40 EUR
ELSE: first a HW-Upgrade (exchange) of the EEPROM (new EEPROM containing SW 32.15 or higher )
followed by an update to Codec 04 version 1.31 will be necessary (via service tool)
costs: approx 1,5 hours + EEPROM = +/- 140 EUR
Vienna
You're a gent sir!
brilliant, sw version is 2.01a!
Now to get the upgrade will apparently cost me more to drive the 300km roundtrip to Rennes than the actual cost of the upgrade - lifes sweet isn't it - hey ho!
again thanks for your efforts!
salut
tony
