BS4 SD file types
What file types can the BS4 now read?
MP3 & WMA.
Up to 2gb SD/MMC card or if software is 2.15 or higher up to 8gb SD/MMC card.
Opman
. According to the documentation, WMA files up to 192, MP3 files up to 320. If you rip MP3 files with LAME encoding, I find that is a very nice recording that will play anywhere. For years I have used CDEX, a free utility, then sucked them into iTunes for use with iDevices. I dont use iTunes for building SD cards, buts that's just me. Updated BS4 software allows 8G card. Not sure of spec.
WMA, does anybody seriously use WMA?
B&O does 👍
Opman;
Per your post: How do you verify the software version on Beosound 4 ?
BeoSound4 in Standby
Press menu.
Turn wheel to select "set up" & press go.
Press 0 0 go.
Turn wheel to navigate in the service menu.
1 in service menu is software version.
Opman
Using the directions, I show number 1. as  AP 1.3.
Is that correct  or is the OS ?
The latest software for BeoSound4 is 2.15. This gives the new features as described in the supplemental instruction book that can be downloaded from the Bang & Olufsen website.
Opman
opman
can you give a link to the supplemental instruction book please, i've looked but can only fins thethe original 32 page job - am interested to see the additions as my sw version is 2.01a
salut et bonne annee a tous
tony
