What file types can the BS4 now read?
BS4 SD file types
MP3 & WMA.
Up to 2gb SD/MMC card or if software is 2.15 or higher up to 8gb SD/MMC card.
Opman
. According to the documentation, WMA files up to 192, MP3 files up to 320. If you rip MP3 files with LAME encoding, I find that is a very nice recording that will play anywhere. For years I have used CDEX, a free utility, then sucked them into iTunes for use with iDevices. I dont use iTunes for building SD cards, buts that's just me. Updated BS4 software allows 8G card. Not sure of spec.What file types can the BS4 now read?
WMA, does anybody seriously use WMA?
B&O does 👍
Opman;
Per your post: How do you verify the software version on Beosound 4 ?
BeoSound4 in Standby
Press menu.
Turn wheel to select "set up" & press go.
Press 0 0 go.
Turn wheel to navigate in the service menu.
1 in service menu is software version.
Opman
Using the directions, I show number 1. as AP 1.3.
Is that correct or is the OS ?
The latest software for BeoSound4 is 2.15. This gives the new features as described in the supplemental instruction book that can be downloaded from the Bang & Olufsen website.
Opman
opman
can you give a link to the supplemental instruction book please, i've looked but can only fins thethe original 32 page job - am interested to see the additions as my sw version is 2.01a
salut et bonne annee a tous
tony
