BS3 software upgrade. Is it difficult?
Our Service Centre in Melbourne say that a software update from 2.7 to 3.1 for the BS3 would not make an Apple TV remote controllable...
yes thats true, but when they already has the BS3 plugged to a PC it only takes a minute to update the puc (stb) also... I don't know any thing about the appel tv, some people in here says it can be controlled so I think it can...
It is easy as long as you follow the on-screen instructions on the laptop (plug in/out, power up/down when the computer tells you to - do not add common sense, then you will have to start all over if you are lucky - which is the reason why dealers do not let you take their service computer home). But it would be pretty straight forward for an average BeoWorlder... it is so much easier than unplugging and returning a product to the dealer.
Roger
do we still have to hand it in to a service shop to get the SW upgraded or someone been able to get hold of software and patches so It can be done ourselves?....its a lot of hassle to get them updated each time....
Cheers
Klas
I would have thought that the dealer will perform this upgrade for you, as it only takes a small amount of time (when my BV7-32 was HD upgraded, they had to perform a SW update, which took less than 20 minutes, if I can remember). You could either pay your dealer to visit you or, if you ask nicely, they may send someone round at their convenience.
I'm wondering what is updated in the BS3 4.0 SW update? Anyone know?
thanks Moxxey - i'll give them a call and see if they are feeling nice this year....my unit got shipped from fabric two days before 4.0 got released so i'm keen on getting the new one and trying it out
Support for BeoLab 10
- Support for Samsung A800 (FDH, EU)
- Support for Sim2 HT-3000 (FDH, US)
- Timer recording (menu and execution changed)
- First time press on MENU goes to the active source, not the TV menu
- Large function implemented in teletext
- Possible to select 'DVD2' as DVD source in the CONNECTION menu+ several software corrections ...
