Hi All,
I have a Bs2 that I've recently starting using with an Essence Remote. Works great for a few days, then it doesn't work at all. At first, I thought the batteries were dead (and they were). A few days later, same thing with brand new batteries (which I did check in case I had some bad new batteries). I thought it might have something to do with having a BeoRemote One also paired so I removed that pair, and same behavior.
I recalled similar threads about the remote losing contact with the Essence and the same fix worked: un-pair, reboot and then re-pair. Has anyone else experienced this problem? Anyone else have the wheelie working flawlessly with their BS2? Any feature I can turn on/off to have this not happen so frequently? It is a fairly old Essence remote if that matters.
It's odd because I'm borrowing the remote from my Essence where I rarely experienced this problem. The only difference I can really see (aside from Essence vs. BS2) is that I now have it in my office where there's other BT devices.
Stan
