BS1 connecting challenges
Hi! I got problems when I swapped my older Comhem router to the latest Comhem router.
Never got it to work with my B&O devices so I changed back and bought two Ubiquity accesspoints.
No problems since then.
Have you added the Deezer login info? That is why the app says "unconfigured".
Also, it is possible to switch BS1 off. You do a long press on one of the buttons under the unit.
Du kan skicka PM till mig om du vill resonera på Svenska.
/C
Great 😁With some help and advise from Hjort I have now chosen the Ubiquity option. Picked it up today and have it now running. The Marten & Oopjen Rijksmuseum playmobil edition ...
The '&' sign in the password could well be a problem. I know from experience that you cannot change the name of the Playmaker to include an '&' sign - I once made the mistake of calling it 'B&O playmaker' and couldn't get it to work.
